Identification help
wayneburgess
Hi. Can anyone help me identify this yard fun kart. Any help would be appreciated. I’d like to restore it back to original. Originally it had Red frame. yellow seat. No numbers or ID tags. rear wheel 6 inch front wheel 5 inch. Thanks. Wayne
While it does have lightweight nylon/Zytel racing kart wheels, the frame looks heavily modified, custom and/or homemade to me. Looks like the seat and the front axle slides via telescoping tubing....
I will wait for the other members to chime in.
Has some nice pieces for sure. Very decent find, imo.
wayneburgess
Hi. The seat rest is not original. Front bumper has been replaced with new metal. Front half of the frame is telescopic with the pedals attached. the seat adjust on rails. It looks like it was built in the factory good clean factory welds. Definitely not a home build kart. I believe the original seat may have been a red fibreglassbucket seat
wayneburgess
over the years it has been modified slightly and fixed up. most of the welds ain’t factory, but I thought one or two welds around the towing eye. and the rear axle mounts were. The 5HP Briggs & Stratton flat Engine is not original, but it is the same era. Thanks for your advice it’s appreciated. IMG_2581.pngIMG_2582.png
Do you think it was made in the UK or imported? I peeked at your location. If there’s any markings whatsoever on the frame, please show them as they could point to its origin. Even markings on component parts could assist.
Where did you get it from, a seller?
wayneburgess
Hi. I’m pretty sure it is British. The the nylite wheels has England written on them. The steering bearing bracket. Has. Picador England written on them. I believe it is some sort. British commercial fun kart or concession/rental. Which is why he has adjustable seat and adjustable front end. Original colour was red with yellow accents. From what I read there was least a couple of British kart manufacturers used those colours combination. I’ve also learned that butlins used to have red karts with yellow or green accents. The yellow paint on the seat in the picture I believe is the original yellow. The red paint on the steering column in the picture I believe is original as well.
British commercial fun kart or concession/rental...
That explains a lot. It’s very tank-like and overbuilt, lots of reinforcement and extra metal, meaning it could very well be a concession kart. Good call. Concession karts also have a lot of refined features like extra ball bearings in the spindles or steering column like yours has, to make the steering light and easy for all ages, plus normal plain bearings or bushings would tend to wear and get sloppy from the daily abuse.
