I was at an auction the other day and bought my daughter a yard cart and then ended up with this motor also. Does anyone have any info for it. I think it is a Tecumseh maybe? It has aluminum blocks that adapt this carb to the motor and another one on the pipe. It has an external vacuum fuel pump. It also came with an aluminum fuel tank. Any info would be great. I have not got it running yet because it does not have a starter assembly but it has good compression and spark. So I think it will run.
Well the images dont work because this forum bolcks the word "d a m n" so if you put those letters in for the **** in the photo link you can past them and look art the images.
