idel mixture screw problem
RonC
Hello, I am new to karts and definitely not a mechanic. But, I cleaned the carb on many mowers and have had good success.
So, I picked up a used Yerf Dog with Tecumseh OHH60 6hp. Anyways, I cleaned the carb and adjusted everything. But, the ideal mixture screw was turning on its own. Then I took it for a ride and when I let off the gas it died.
During inspection I realized that the ideal mixture screw rotated out and is now missing.
The guy gave me a spare carb so I cleaned it and put it on, same thing happened. Screw missing after one ride. :)
1. Why is this happening?
2. Should there be a plug holding it in?
Is this a part I can buy or should I buy a new aftermarket carb and where's the best place & what brand.
Thanks in advance for your help.
Russ2251
AZUSA:Powered by LAWN-BOY
Please post good clear photos!
Usually the low speed mix is not adjustable.
edit:
Should have something like this:
Poboy kartman
Senior Moments Member
White Settlement Texas
What he^ said.....it's almost nearly mostestly mostest likely....that the "idle screw" was indeed a pilot jet....which is meant to be screwed all the way in....and is not adjustable....just the fact that the carb was even working without it being screwed down tight....means the carb was probably still dirty and fuel starved.....
So.....good news , bad news, those carbs are pretty ****le and temperamental.......good news....you can get a whole new one for about $20 or so online.....
EDIT: I can't believe that word was censored ^ it started with an "F" ....but that only replaced the "P" in pickle? ????
Poboy kartman
Yes Russ, that work is on the censored list... you can blame Doug for that one :lolgoku:
Like I give a flick....if flickle (****le) is censored....but why blame me.....if we didn't have Tecumseh carbs....we wouldn't even need the word......WAIT!!!!
I forgot about women and politicians.....:lolgoku:
EDIT: I guess the editing software is just fikkle..... or maybe that's a bad word somewhere else in the world....
RonC
photo of carb missing screw
Hello, Here is the requested photo of the carb. My finger is pointing at the spot the screw was In.
Yes, the screw or needle is what Russ posted.
Can I just by (2) new ones somewhere? I don't mind buying a new carb as well but, I have (2) cleaned and ready to go carbs without that screw.
P.s. It sounds like I created this problem myself by not making that screw tight. I thought I needed to leave it 1 to 1 1/2 turns out. I thought it was an idel mixture screw.
My own stupid mistake for not knowing what everthing was or did Before I messed with it.
Thanks again
RonC
Poboy, Anywhere in DFW to buy parts over the counter for karts? Also, are you goind to the swap meet next weekend in Decatur?
Thanks
Poboy kartman
Thanks
I doubt it. I don't have any money. I didn't know there was a swap meet in Decatur next weekend....I thought that was in February.....
I will be attending the GoPowersports swap meet on the 30th in Keller.....
RonC
Poboy, Yes I seen the Swap meet in Decatur on CL under ATV / UTV but it mentioned go karts & small engine's.
Also, thanks for the part numbers.
RonC
Sorry, Thanks Russ for the part numbers and info.
And everyone else who replyed. :)
RobertD
Administrator
Texas
weird. I'll fix it.
