I'd like to add reverse any ideas how?
modelengineer
Lord of the noise
Sydney, Australia
See if you can get an outboard motor, in the leg of the outboard there is usually a set of good quality gears which do forward and reverse. Probably the cheapest idea, but may be hard to put on if your kart is already built.
dunebuggydiy
nederland,texas
fowler
Bullsbrook West Aus
This is a big talking point with the mini buggys
The most common solution is to use a starter motor from a car
There is a Subaru one that is common but not sure which one
U can get teeth cut into the brake disc
Then run the motor to it
If u are using an e start motor then u are half way there
Even the price of machining and a brand new starter it is cheaper than a FNR box
zbuck
Ft. Wayne, IN
:wai: Tiller that has reverse. As the reverse works off the cam, there are two belts with an idler that kicks forward drive out, when switching to reverse. An no there is not two crankshafts.
dunebuggydiy
nederland,texas
would a lower unit from an outboard work well for a fnr gearbox? if i got it to run off a chain to the box off my torque converter then a chain from there to my rear sprocket?
