I Want To Go Fast!
tomi217willis
ok finally got my clutch working great, but my go kart is not fast enough! wats a fast and cheap way to make it go faster? i need all the ideas i can get!
GXMATT
Mini Kart Guy
uk
de govern :D easy when you know how. and definatley sort the air filter! if you got some notes to burn you could uprate the carb. these engines have alot to give when you have a fiddle
GXMATT
Mini Kart Guy
uk
yeah sounds like the ratio is probably high if your getting no top end out of it. sprockets are cheap :D
BradenM
Etre Et Durer.
In a big jar of Nutella, nom nom nom
Remove your gov, remove the plastic bit covering your air filter. Many people believe that an ungoverned clone's flywheel is going to explode; evidence currently suggests otherwise however if you can get a Billet aluminum flywheel, and your happy with the price, go for it.
GXMATT
Mini Kart Guy
uk
change of tone?
