i wana buy this welder
SpyGuy
Hooligan
Tucson, Arizona
I'm also in the market for a welding setup. I've never done any welding before, but I hear the wire-feed electrics are pretty good. Can anyone give me a good one to start with? I don't have access to a 220v, so I was thinking a small 110v setup would be good. I'm just going to be using it for small projects, like pocketbike repair.
Kenny_McCormic
Kartless....
Michigan Troll
A cheap $100ish fluxcore wire feed unit from a tool sale/harbor freight would be fine for you, just watch that duty cycle and use high quality brand name wire.
SpyGuy
Hooligan
Tucson, Arizona
Thanks, appreciate that. There have been a lot of things I've wanted to do, but I never learned to weld, so this will be a first for me. I've heard from several people that wire-welding is fairly easy, now I just need to pick up a rig and do some.
SpyGuy
Hooligan
Tucson, Arizona
Point and shoot ... that's what I'm looking for, lol. Yes, a good mask and gloves are a must. Thanks for the help.
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
has anybody used this welder before i need input!!
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=55060
im a first time welder and i dont have an accesable 220v outlet
:confused:
I say go 4 it!I looked at it at my local Harbor Freight and liked the system and set up! I have a Sears 120v mig welder that I have been using for 10 years and all I have replaced are shielded 1 lb. spools of .030 wire. I have successfully welded 1/4" with settings on high. 3/16 is a snap though. YES, that welder should perform as well as mine does. I paid $200 for mine 10 years ago.
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
While you are at H.F., get the auto solar helmet. My setting is on 9 and I love the fact that I don't flip my lid :D anymore! YES, cheap auto helmets work. Paid $49 for mine.Worth a million to me though. Scott Ooooooooops. I see now that it is a STICK welder. Me and stick welders don't get along!!!! Go to MIG if you can. Not much more money either and very nice welds and no 'STICK' sticking! Migs are a dream to use!
Kenny_McCormic
Kartless....
Michigan Troll
Stick welding is the only way to weld heavy duty stuff! There are rods that make stick almost as easy as fluxcore. 7014 comes to mind, flux burns too cold for the arc to peel it back on the rod, it automatically holds proper arc length, scratch and drag.
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
I have been practicing with my Craftsman 120 v. Arc welder and find that it gets easier if you are on a higher than normal setting or the tip of the stick gets hot from sticking enough times LOL. I like my stick welder and will continue to practice. Them 120 volt systems are hard to kick start. I will soon buy a 230 v. from my buddy. I am sure things will click then. But for now, you need the setting higher than normal to arc easier. Yes, they work once you learn the settings. BTW, I did pay $99 for it at Sears 10 years ago also.
Kenny_McCormic
Kartless....
Michigan Troll
If you want to get into stick welding a 230 amp unit is the only way to go. The sears fluxcore welders are now some crazy price last I checked.
rhytonen
Buy a Chinese TIG off eBay, but shun the 110v and the combo (+plasma) units.
I got very lucky (knock knock) with an orange Hutai brand 220v/200a/pulse machine for $350. (but the seller hid the brand name until I got the welder and could read it on the case.) Although the workmanship inside is obviously cheap, I baby it (lives in the house until needed,) and I've never had it shut down during kart work (which is sporadic, and all I do.) It would probably not be acceptable for a pro using it every day on jobs.
If your house will support a clothes dryer you have a 220v line readily available. ALL electric service is at least a 220v (i.e., 2-phase, split into two 110v circuits) line. Learn about it. On every (at least 220v) welder you need to choose, buy and install a plug anyway. They usually come without one, just a bare wire. IMO 110v welders just aren't stable enough, even though you may not need the extra current for kart work. Of course an expensive welder, like the vastly preferable small Miller machines, will also be stable at 110v, but they're well over $1K.
TIG welding is so clean, precise and confined, that you can safely do it on your kitchen or dining room table.
(- of course you wouldn't, as it also involves lots of grinding, filing, fitting and cutting of metal beforehand...) And once you weld your piece it's usually VERY hot. But the "arc" itself is tiny, contained in a gas (you need argon) envelope, and soooo precise. There are NO sparks or slag with TIG.
modelengineer
Lord of the noise
Sydney, Australia
I'm about to purchase an AC/DC 200 amp TIG machine (made in China) but from a local company. I'm going for one of the IGBT machines (as opposed to the more common and cheaper MOSFET machines), because of the apparent increase in reliability and they're cheaper to repair if they do fail.
I'd be a bit wary of buying a machine from e-bay. Even if they offer a warranty you don't know if the seller is going to disappear at any moment, and any warranty claims require you to freight the machine to the seller (at your cost) leaving you without a machine for some time.
Though here in Australia an American made machine isn't really an option, seeing as a Lincoln machine of the same specs as the chinese machine I'm buying is close to $7,000 AUD, and the chinese one is less than $2,000 and looks just as good.
Kenny_McCormic
Kartless....
Michigan Troll
You can find em used here in the states for less than a few hundred. Does the Chinese unit weigh as much as the Lincoln? Is it a copper wire transformer?
pmat
noob
lake wynonah, pa
i just got the little 90 amp flux wire welder
its pretty good
i've been welding 1/4'' stuff just fine
but if you go stick
get one of those lincoln 225v 225amp stick welders
there are alot of them around
i've seen em everywhere on craigslist for about $100-$150
i have one and it is amazing... anyone looking for a stick welder should get one
porsche930dude
Upstate, NY
beware flux core wire is super expensive compared to plain gas wire. i have a licoln 100 use it weekly for 9 years no problems 75% argon 25%co2
