i think i messed it up...
Bluethunder3320
so i took apart the XR100 and forgot to mark the chain with the cam gear.
uh oh... what do i do now?
Bluethunder3320
cool. so TDC and O with the notch on the cam gear and rocker assembly.
lets see if i can do this.
thank you very much i will see what i can do and get back on here.
Bluethunder3320
i got it all back, and no start.
:censored::censored::censored::censored::censored:
pics soon... i just dont know how to get the engine to exactly TDC so that i can line up the chain.
Bluethunder3320
Russ2251
AZUSA:Powered by LAWN-BOY
Place a wood dowel or even a pencil in plug hole. Rotate engine until pencil is pushed out as far as it will go. Rock flywheel until you are sure it is at tdc. This should be done on the compression stroke when both valves are normally closed.
Bluethunder3320
alright i will go do that now. (sigh) its coming apart again..... the chain is so small that im always worried ill be one little link off..... due to slack.... the good part is i wont have to take the rocker arm assembly or head off again...
now let me be careful so i dont drop the chain into the crank case again. magnet on a stick helped fix that. :p
EDIT: kendel. you go rip apart an XR100 and put it back together the same way it came apart! then let me know! haha.
Russ2251
If you're a link off you'll know it pretty quick.
Double and triple check your work.
Once you are confident of proper assembly, rotate engine over manually to be sure there are no interferences.
May the camshaft gods be with you.
Bluethunder3320
okay so i tinkered with it for a few hours more. i found out that i had it 180 degrees reversed/advanced earlier today so that the piston moved down during exhaust stroke...
well the exhaust no longer makes a sound when the exhaust valve opens. is the timing still a little off?
it will not start still.
also the exhaust rocker arm is tight, it used to be loose, and the intake is loose like normal.
Bluethunder3320
sooooooo i worked on it for a few more hours today. NO compression at all. it all was hissing out the exhaust.
so i realized, from when i had the timing not set right before, and i kicked over the engine, the exhaust valve opened into the piston and bent.
ugh.
i bent it back and put it all back together and NO start but a very loud backfire.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
ugh.
I cant really see you being able to bend it back 100% right.
r97
Measure twice cut once
Massachusetts, USA
This was good advice ;)
I would definitely get the new valve. I'll go see if i can possibly go find it cheaper for you.
EDIT: Not looking good..... You could try a junk yard, or maybe get a spare one from a seized motor at the Honda dealership?
