i need some thing to tension my chain..
kartingizm
Murray Hardrive Gokart
hey guys ive havent been on the fourn in ever but i need someway to tension my chain. i dont thing a tensioner will fit. any help?
You really only have three tensioning options from where I stand
1)Slotted engine mounts
2)Adjustable axles mounts
3)Tensioner- whether manual, or automatic
Sometimes, there's a fourth option. Depending on engine/jackshaft/axle orientation, you may shim the engine, jackshaft, or axle to tighten the chain. This will only work with the chain run in a vertical or near-vertical orientation.
island
Guam U.S.A
Guam U.S.A
Skate board tire chain tensioner
[/IMG]
Jcotz
...wasn't there
NY
I was able to put some shims on the screws holding down the engine, and it worked like charm. No problems at all yet.
Orange Krate
North Texas
You should start by saving your neighbor from drowning in his catfish pond...it worked for Jimmy in A Miracle of Catfish by Larry Brown.
