I need some help
Rdecandia22
i bought a go kart from some old lady it hays a 5hp briggs an stranton motor the back tire is really in rough shape i want to change the tire but i cant really get the tire off the rim any tips??
Also is there any website that i can buy a muffler from???
Hendu3270
banned
Pearland, Texas
I have similar tires on mine that I am needing to replace. So I'd like to know this process as well. Surely it's nothing like a vehicle tire and is more like changing a bicycle tire?
robbie
Osceola, Missouri
A photo of the rim would be more helpful, but it looks like rather standard equipment. You'll probably find four bolts going through the middle of the wheel. Removing these will separate the two halves of the wheel rim. Be sure there is no air pressure in the tire when you take it apart because pressure will cause it to pop apart and throw parts at you when you get the last bolt out.
If you're riding on pavement you can wear the tire off until you can see the air inside, and it won't hurt anything. But, if you're riding off-road maybe you'll be more likely to pop a sharp rock through the tire if it's worn off badly. I always like to use things up all the way and get my money's worth, so I wouldn't bother with new tires until the old ones were just about gone if there aren't any sharp flint rocks around.
Blazkowiez
Kart Aficionado
Houston, Texas
Suggestions:
-remove air from tube inside tire
-unbolt 2 rim halves
-slowly work around rim with large screwdriver (push down evenly working around).
-replace tire and tube if necessary
-only inflate tube slightly so as not to pinch tube between rim halves
-bolt rim back together
-air up tire to psi recommendations accordingly don't over inflate, those rims can be dangerous
