I need some help
Randy46843
So I’ve started building a go kart/buggy type thing and I’m just a little confused on how I would put the front wheels on. This is what I’m workin with anything helps 🙏IMG_3291.jpeg
Actually you need to cut that front axle off and start over. Scratch that, just cut the spindles and tubes off and weld on some c brackets and buy some GoKart spindles.
Actually, I used a similar axle on the Naughtagator. There are no bearings, the wheel has(d) greaseable bushings that run on the spindle. The wheel has a zerk fitting. That thing that looks like a bearing is a dirt/dust shield thingy. That is typical of the (cheap) lawnmower axles I have seen.
