I need some help again lol, I made a video
anderkart
Surprise Arizona USA
If your kart is not very fast, you might not even notice a problem there.
But something kinda easy you could try is:
Spin the wheel just like your video again, accept this time carefully hold a crayon up near the end of the sprocket teeth so it will only leave marks on the teeth of the high side of the wobble.
Ok, now you know the sprocket needs to be moved slightly in the direction opposite of those crayon marks. Try loosening the bolts, push and hold the sprocket in that direction while re-tightening. Then test spin it again.
If its not any better you could probably use a rat-tail file to slightly egg-shape 1 or more of the sprockets bolt holes until the sprocket can be tightened up running true and centered.
e85
The great NW
Thanks anderkart, I only have it geared for 23mph so I was thinking of just leaving it. But I like the file idea. If thereare any problems I will try the fileing idea. Thanks again
r_chez_08
Should be in the shop...
Cornwall, UK
Looks like this would tighten and loosen the chain in a rotation. Could cause excessive wear or chain throw. Imo i would file it.
Rob
r_chez_08
Cornwall, UK
My kart sprocket and wheels wobble like buggery too, but not in that direction, and that will tighten/ loosen the chain.
Just saying, it is a lot easier and cheaper in the long run to egg the holes with a file if anything goes wrong.
Rob
