i need help w/ 12.5ohv mini bike
elfonzo91
i have the 12.5 ohv briggs and stratton off my old racing mower and i'm wondering how i can convert it to run horizontal:confused: i'm planing to build a mini bike or trike and put it on that.
my plan it to make a fat tire mini bike w/ 18" wheels front and back. i want to gear it to go 25-35mph its gonna be for riding in snow, mud, pretty much anywhere i can
the rims are 5 bolt lawn mower rims
tires are tubeless turf savers
freakboy
the names 'mater
hick town
ok first you need to open it up remove the oil slinger... then after that you have to make a rod dipper.. then turn the carb 90* so the bowl is facing down.. after that you gotta make up a motor mount so it can work 90* and still be strong enough to suport it.
elfonzo91
ok and suggestions on making the oil dipper?
as soon as i get some plans drawn up for the bike i'll post them
elfonzo91
what do you guys think i need opinions please
i might go with 2 tires in back maybe 1'' in between them
both front and back disk breaks
1.5'' or 2'' tube for the frame
braided steel gas line
electric start, battery, 2 halogen head lights
heavy duty chain and sprocket tractor maybe
low drag bike look
custom gas tank
color?
Ibnzmonkey
Keep Austin Weird
Austin Tx
i would use 1.5" tube for the frame, it will be lighter and easier to bend. The 12.5 makes a serious amount of torque so you should use like a 6" x 12" wide x 15" tall. Ive found that this size tire works best for high torque applications. I use them on my Shifter Karts.
elfonzo91
cool i'm getting all the parts 2gether 1st
i can get 2" tubing for $0.60a foot
