Thank you, that explains absolutely everything... The reason the ratio you poseted seems so offside is that the originator of these "plans" is using a lawn tractor tranny, which has it's own fixed ratios and he is using that sprocket combination to create a better final ratio for his project. Please note that if you do not use the same tranny, those ratios will not be appropriate. In fact, I have not crunched the numbers yet, but there's a chance it's not even the right ratio for him. That, AND- some (if not most) tractor trannies are not up to the rigors of karting...
EDIT- Further thoughts- I don't like the rearend arrangement. While the independant swingarm is not a bad idea, he's got waaaay too much leverage on those skinny@ss half-shafts. Those will bend, just a matter of whether it's during the first two minutes of offroading, or the second two minutes of offroading...
Furthermore, and this is just my own personal opinion- building something that is potentially very good is a total exercise in futility if your drivetrain sucks. Putting a lawn tractor engine and tranny in that thing is just a waste.
