Before ya all start piling on, it has been well established that hydrosatic transmissions are not suitable for high speed and/or high power applications. They do however work well in applications like ride ‘em mowers and low speed yard junk.
l’m planning Naughtagator V2.0 and want to use one for that. It has variable forward and neutral and reverse.
Someone smarter than be tell me if this will work.
The trans has a vertical input shaft. Its easy enough to find an engine with a vertical crankshaft.
Rather than using a V belt between the two, l propose stacking the engine on top of the trans with a flexible coupling between the two, and the necessary support for the engine.
l can’t do the fancy sketches some can, so use yer imagination.This is the coupling l’m referring to:
Lets hear it….
Lets hear it….
