Making a modified Grand Daddy project, it's nearly complete but I'm having a lot of troubles getting the brakes to work. This is the brake kit I'm using:
1" or 1 1/4" Hydraulic Brake Kit - Red | 600505R or 600510R | BMI Karts And Parts
I attached some pictures of the setup. I had it done as just a crude setup for now, I'll clean up everything once I get it all running properly. My issue is that the brakes feel VERY soft. You can easily bottom out the brake pedal and you get very minimal braking performance. I bled both lines for a long time, multiple times, with different methods without any improvement. I even purchased the bleeder kit thinking it would help: Brake Bleeder Kit | 600606 | MCP 912 | BMI Karts And Parts
I followed their directions listed here: https://www.mcpbrake.com/brakebleeding.html
I found some other ideas and suggestions online for different methods of bleeding and I haven't gotten any improvement, regardless of the bleeding procedure.
Is there something obvious I am missing? I'm using DOT 5 fluid and I'm using Hydraulic lines.
My build is longer than most applications, so I'm wondering if maybe the length of the setup causes the system to lose power? I'm hoping you guys can spot an obvious issue, or provide a recommendation.
