Huston...we have a problem
The ceramic seals aren’t prone to going away like rubber seals do. An injection pump governor failure is just as you described. Saw a lot of them fail on the old Oldsmobile Detroit diesels. What ever it was that happened you will know more at the autopsy. Time to break out the back up truck.
For more info
...& to further the discussion
...this truck is a 2003 Isuzu NPR-HD
...with the 4HE1 (4.8 l) Isuzu Intercooled Turbo Diesel engine
First pic is of the turbo unit
* The metal tube, with the bolt going thru it (AKA Banjo fitting) on top (of the turbo) is the "pressurized" oil inlet line
...it provides lubricant (aka motor oil) to the Turbo unit
...& there is a non-pressurized oil return tube (not shown) coming out of the bottom of the Turbo, that goes down to the oil pan (area)
** The (2) metal lines, on each side (also with Banjo fittings) are water coolant (inlet & outlet) lines
*** The vacuum actuated "bar" is connected to the Waste Gate (on the exhaust side of the Turbo)
How this system "works" is the fresh air (from the air cleaner) comes into the Turbo, thru the big tube on the left (w/water droplets)
...then, the air flows, out of the Turbo, thru the "upper" big tube
Then, the air goes thru this tube
Thru the Intercooler (in front of the radiator)
...& then/finally, into the engine, on the other (far) side
So, as I mentioned previously, it seems like an oil seal "failed" (under that pressurized line)
...& allowed oil, from that pressurized oil line, to enter the "air system"
Which ended up "fueling" the engine
...& causing the "runaway" situation
Sparkwizard
Richlands ,NC USA
Just an opinion...the death rattle at the end of that video sound to me like bottom end ran out of oil at high speed.
I do not think it overheated. I think there is bad news in the oil pan.
We gonna find out :thumbsup:
Did ya notice the box truck, in the background?
* Winter storage for my Polaris, Sequoia & Tsunami EA racers:cheers2:
It's the same type truck
...early 2000's Isuzu NPR
...w/same 4HE1 Diesel engine
It runs & drives
...but, the engine has a "miss" to it
...& has been "diagnosed" to have a "burnt" exhaust valve (hole in the valve), on the front cylinder
So, the Turbo unit "should" still be in "good" working condition ;)
To double check my "Oil seal failure in the Turbo" theory, I removed the "big tube" on the "air out" side of the Turbo, on my flatbed
Yup, the inside of both the Turbo & the tube are coated with motor oil
Motor oil even came drippin' out of the Turbo, when I first pulled the tube off :ack2:
Here is a view on the air "in" side of the Turbo
...& the impeller (inside of the Turbo) looks ta be still "intact"
...but, everything is definitely oil saturated (it should be mostly dry in there)
Then, as a test/for comparison purposes, I pulled the same tube off of the Turbo, on the box truck
...& it's "bone dry" inside (as it should be) :thumbsup:
Update:
The Isuzu 4HE1 Diesel engine holds 12q. (3 gal.) of motor oil
1st.)
Assuming the worst, I thought/figured that it would be pretty much empty
...but, to my surprise, got a pan full :bannana: when I drained what was left, of the oil out of this engine
2nd.)
Using a couple of gallon jugs
...it seems like there was still ~6 - 7q. (or ~1 1/2 gal.) of motor oil still in the engine
* So, it still had at least 1/2 of the normal amount of oil, that it is supposed to have
...& this would, or at least seems to indicate, that it didn't "run dry" :wai:
3rd.)
Also, I didn't see any, "floaties" (like brass grindings or dust, from the main bearings)
...or see...anything...really...at...all (like discoloration or any foreign debris) when/while pouring the oil into the jugs (totally jet black...like usual)
...& didn't/don't see anything in the bottom of the drain pan...either :)
Yesterday, I also I worked on removing the Turbo unit, off of the "parts" truck (first)
...but, ended up "breaking" a couple of the "mounting" bolts off, in the process :confused:
* These bolts are for mounting the Turbo to the exhaust manifold
...the (2) "inner" mounting bolts, go from the top down (as seen in the pic)
...& the (2) "outer" bolts, go from the bottom upwards (not shown)
There is also a front "support" mounting bolt that I was kinda worried about
...but, I got 'er out...without any issues :)
I quickly found out that this Turbo unit has (8) different connections :ack2:
...(2) oil lines (in & out)
...(2) coolant lines (in & out)
...(2) air tubes (in & out)
...plus, where it mounts to the exhaust manifold
...& also, where the exhaust pipe connects
Wholy crap :huh:
So, after a couple of hours
...& with a bit of persistence...I got 'er off :2guns:
After ALL (4) of the actual mounting bolts broke, I did some re-evaluation
...& decided to NOT attempt to remove the exhaust pipe bolts off (as they would potentially/probably break...too)
So, I devised a plan to just "wiggle" the whole unit out
...with the exhaust pipe still...intact
Now, I can easily "get to them" with some heat
...& try to get them bolts out (hopefully) in (1) piece ;)
* Also, you can see (in the pic below) the (2) "up from the bottom" bolts, that broke off in the Turbo unit
...but, "luckily" there seems to be quite a bit of "stud" left to be able to "grab onto"
...& (hopefully) get 'em out (after heating) :cheers2:
This is what the exhaust manifold/area (on the parts truck) looked like, when I took the Turbo unit off :thumbsup:
I was expecting to just see a simple (probably metal) "gasket" in between the Turbo unit & the manifold
...but, this is what it looked like :unsure:
Looks kinda wierd to me :huh:
Mission Control Houston to Apollo 13.
How is it going out there?
Hey Denny,
Well...for today's daily log/progress report :smartass:
1.) With the help of some (actually a lot of) heat, I got the broken studs out of the "replacement" Turbo unit
...& got the (3) exhaust bolts off too :wai:
2.) I got the "damaged" Turbo unit off of "my" truck :thumbsup:
But,
3.) Even with lots of heat, both of the Turbo mounting studs/bolts broke off, in the exhaust manifold on "my" truck
...& we needed them studs :mad2:
So, currently...re-calculating...re-calculating...re-calculating (workin' on "Plan B") :popcorn:
Hey Fellas,
Today's daily log/progress report
While "re-calculating" I remembered that there was another "parts" engine, in storage
...& that should have a "good" Turbo on it :unsure:
It "was" in a non-running truck, that I bought years ago (just for the towing/flatbed, that was on the back) :thumbsup:
...& it just happened to be an early 2000's Isuzu NPR w/a Diesel engine :cool:
* The cooling system on this truck had "frozen up"...somehow
...& this "freeze up" had "blew out" or cracked, the sides/water jackets on the block
...&/so, the engine was technically "good"
...but, it wasn't "actually" usable
...so, I saved it "for parts" :cheers2:
* Side note,
...my wife says I'm a HORDER
...& I always say "I may be ably to use this...sometime"
Well...HONEY...that time has come ;)
On top is Turbo #3
...& the bottom Turbo is the "bad" or damaged Turbo, that I removed from/off of my truck
This time I left the Turbo, mounted on the manifold
...& am gonna just try-n-mount 'em together as a whole "unit"
This way we ain't gotta "deal with" them "problematic" Turbo to manifold bolts :wai:
Also, notice the ~2" tube coming off of the back of the manifold?
The bolts holding that tube to the manifold in my truck, also broke off :mad2:
...so, this is another one of them...ain't gotta "deal with" them "problematic" manifold bolts situations :p
Now, I had to order a "manifold to head" gasket
...&/so, it's supposed to be here Monday :popcorn:
Nothing as good as having an ample parts stash! I’d still either drill or blow out with a torch those broken bolts though. You know, just in case one day. But I’m a worry wart.
