Hunting parts for the next Briggs 5hp build
Thepartsguy
I have on hand
-spare arc rod stock length
-Clements cylinder head
-electronic coil + drop bracket
-Flywheel
-cam
-Wiseco standard bore piston
-Bearing block 132232
I still have yet to buy
-22lb valve springs
-billet arc sidecover with crank/cam bearing
-big tube exhaust/rlv muffler
When I do finally get those last three needed hotstock parts I’ll start assembling.
Bonus points
-Mild port on intake/exhaust
-eyebrow shave
-tons of small pulsajet tweaks OR a f&b/mikuni setup.
-Methanol?? < always wanted to try this..
Thepartsguy
OHHH it all makes sense now I was like that piston isn’t a stock 3.875 .590 height part number?? Finally found what I was looking for 4.475 height rod for this one! Building a stroker! 8762381B-327D-43D8-BD77-7F3776D790CA.jpeg
Thepartsguy
I know NOTHING about a stroker 5hp BUT this is 2023 and I have a phone how hard could it be?
It looks like 1986ps is 2.5625
4.475 arc/horstman rod
comet kart sells spare 2562xl ring sets
cs-13 circlips are very available and cheap!
s-567 wrist pins are very available and cheap! Isn’t there a 4.475 horstman rod for like $50 on eBay? Or $99 directly through arc? So every single part to build a stroked standard bore 5hp can be bought cheap. The hardest part is finding the piston itself?
I now am hunting a 4.475 rod preferably used.
Thepartsguy
Oh my! So I have a chromed wiseco standard bore that fits a 4.475 AND a 4.5 rod. Pictures from OMB show a 4.475 horstman next to stock 3.875 briggs rod.
Block/cam work are needed to clearance this rod.
-Rings 2562xl
-spiral lock cs-13 wiseco
-s567 wrist pin
^^^^^^^^^— All ordered so I have spares for this piston.
To get this whole deal in motion all that is left is an actual 4.475 rod. I do not have one I those (YET) and to fit it and clearance what’s needed.
Then buy
-dynocam springs
-4.475 or 4.5 rod arc/Horstman
-exhaust
-arc sidecover
Thepartsguy
I’m selling some more spare tools tomorrow and I’ve found green stripe 32lbs springs a precision cam and the hardware kit for the springs along with a 4.5 rod all from the same seller! So i’m working stuff off the list.
Thepartsguy
Got a Not cheap intake.. And a $15 Tillotson carburetor.. Cracked open the tilly and I’m surprised it’s not a rusted ethanol mess...6E28C4BE-570C-45ED-BA3A-18BD9C1F6F09.jpeg9B93D0F0-D7A2-49AE-BB0F-F003668D2179.png4B33CBAD-D40A-4875-B1E9-471512607FDC.jpegFA3DCCCB-A417-4726-BB44-17EADFB7F452.jpeg
Thepartsguy
Well parts gathering is near complete. And I’m still currently in the middle of selling off random bits here and there. I have the billet flywheel/drop bracket. All that’s left is 100+ lifters and an arc sidecover. DF39E74B-DBD7-4590-8055-F29B25FD57A7.jpeg4617DAFE-E751-4FB8-A1C2-08B1C6CE67C7.jpeg
Thepartsguy
Why do you need 100 lifters? Most you should need is 2.
Ahahahah I was told to weld to the lifter tip to gain what was ground off the base circle and it would probably be ok. But I think I’ll spend the money.. dynocams still has the cheapest shipping option of $35+ I’m not sure if they refund what‘s not used on shipping or not. But the cost of the lifters + $35 shipping is still the cheapest I can find them new.
Thepartsguy
I still need those 1” longer lifters.. Also I’m hunting for a Billet sidecover with a cam bearing not a cam bushing.311F3822-652F-4283-A389-54D2892C0309.jpeg
