Hub??
It will if the bolt pattern is the same. Otherwise you'll be drilling more holes, which you don't really want to do. Do some measurements of your sprocket & see what you come up with.
Other than that, contact the sprocket supplier & see if they can help
anderkart
Surprise Arizona USA
We can probably find your hub, but first you need to accurately measure/post your sprockets bolt circle pattern. Measure across and from center to center of those 2 holes like the pic below.
The hub you need will be a 4-hole model, your sprockets just has an extra set of smaller bolt-holes drilled, in case they're needed.
