Hub frozen on axle
jpenn82
I have tried a wood block with a hammer and this thing is on there. Any other things I could try? Maybe a pulley puller?
Lots of penetrating oil and heat, preferably propane or MAPP gas.
Is that aluminum on steel?
Pulley puller would help, along with continuing the hammer and block of wood method. Cursing helps too, and after a while it comes along naturally anyway. :censored: :D
Remember, you want to try to heat just the hub alone so that it expands from around the cold or colder shaft.
It's hard work for sure. BTDT.
