Howdy, y'all!
eudemonist
New karter here, from the suburbs of Houston, TX. Worked in the golf cart industry for some time, some time ago, and recently been fooling around with go-karts. Got a single-seat one-tire-fire that usually runs a Predator 212 Hemi and just recently acquired a Dang Feng with electrical gremlins. And since I gotta join up to peruse wiring diagrams, and I gotta introduce myself to join up, well, here we are.
Hopefully I'll be able to contribute at some point; in the meantime, thanks for being a knowledge repository!
Welcome.
Sounds like you'll do just fine.
Those DF karts are a wiring pain. Luckily their not complicated. New harnesses can be had for dirt cheap so dont feel bad just starting with a new one. Most issues are the craptacular connectors.
eudemonist
Lmao @Denny dunno that I need to learn THAT bad...
@Whitetrashrocker I think I'll be alright with this harness--cart fires up and runs if I jump the solenoid (think my starter relay may be shot, but need to explore a potential brake switch lockout), which is the biggest thing. I don't really grok the electronic choke, though: I've read there should be a choke button somewhere, but I've also read that it just hooks up to 12v and does its own thing? I don't rightly know.
Thanks for the welcome, y'all!
The brake switch and other starter lockouts can be bypassed by shorting them or opening them depending on how the switch works. Thats a your safety decision though.
I'm not familiar with the electric chokes. Can't be that hard.
This is a decent part supply site.
eudemonist
Quick update:
Had the kart idling good, then it stopped and wouldn't fire back up. Drive clutch wasn't sliding, so had to pull/clean/reset rollers--didnt help my no-go though. Ended up busting the autochoke needle mechanism messing with it, so went ahead and replaced the whole carb for $25, since I was also getting bowl leaks after having to drill out rivets.Still no go. Spent a day or two stymied, messing with grounds, thinking I'd missed a kill switch, but no joy. Finally got frustrated and went back to square one: turns out, while idling nicely as per above, musta locked some carbon loose and shorted my plug, so was no longer getting a spark. Doh!
Running dandy now, though, and don't even have to jump the solenoid! Currently working on getting all the calipers freed up, as it stops okay, but bounces when driving. Seems the ceaky old brakes aren't disengaging quite, so they need some attention and grease. Once that's done, I believe I'll be at full drivability.
