How would this flywheel cool?
solomon
ca
Interesting. I have acquired a flywheel from a machine shop that looks similar. Was going to use it but maybe not
Gokartbill
Atwater,Ca
Now correct me if Im wrong but you don't nessarily need the plastic cooling fins for lets say a 4 stroke engine (Ie: Honda, clone, flathead). These engine were originally made for stationary jobs such as on a rototiller, lawnmower, etc. which needed some extra cooling because of low speeds. When putting it on a fast go kart the cooling is now being done with the wind blowing over the finds when driving. Not saying they shouldn't be taken off, any help with cooling is better
well since the hot end of the engine isn't facing the wind, and the side facing the wind is more often (at least partly) covered by the seat...
I think you NEED the cooling on a kart if you intend runing it longer than 10mins in a row ;)
porsche930dude
Upstate, NY
yea the people that run jr dragsters usually dont use a shroud or a flywheel with cooling fins since they just run for a few seconds at a time. some of those aftermarket flywheels you can bolt plastic fins
Unless you're running one of the aforementioned Jr. Dragsters, I highly suggest not defeating your factory cooling system. Intact, it's highly efficient. Disabled, it'll roast. These are not, by nature, free-air engines.
solomon
ca
Thanks for the info. Guess i have 3 motors going in the dumpster. Received them all with the flywheels machined down. Oh well :/
just get the plastic fins and attach them...
or... if that's not an option get three flywheels ;)
porsche930dude
Upstate, NY
on a gokart or minibike itll cool enough to survive aslong as you dont have any shrouding on it but then you have to do something else with the pull starter. It has been done. Doesnt take alot of air movement to keep it under control. Like air cooled motorcycles dont have fans even 4 wheelers that dont go that fast
solomon
ca
Does anyone think its a bad idea to run an ungoverned engine with a machined stock flywheel? I just feel like the flywheel would come apart easier than if it had never been touched.
jandj
Williamsburg, Va
My two cents worth: If you kept the stock valve springs you are probably OK as your RPM's are still going to be limited. If you run heavier springs, better to err on the side of caution and run a billet flywheel & rod....especially if you plan on a lot of high RPM use. Nothing will ruin your day like suddenly becoming the owner of a 2 piece block.
solomon
ca
:furious2:I couldn't agree more. But you can not find a billet rod for any of these engines. And the modified flywheel disturbs me let alone not knowing what **** rpm im turning them at.
