how to take apart 500/ 858 driver?? and help me find belt
PolarisXS2
Im not sure if it is a 500 or 858 I cant tell but I took it apart a little but once I took the snap ring off and pulled the cover off I could see the rollers but I want to take those out so I can remove the rubber things so I can clean it with brake cleaner. ALSO does anyone know where I can purchase a 300661 belt?? It looks very worn and VERY LOOSE but the CD measurement is 12" I think more towards 12 1/4".
PolarisXS2
thanks, that was a good read and it helped me with some of my problems but I still want to remove the actual roller arm. On mine I have it up to the first plate being removed but the roller arms have a great deal of pressure against the middle and I don't know how to get them out
PolarisXS2
new problem. It is stuck in the overdrive position. I tried putting it back on the motor and running it to see if it would put it back to the idle postition but it doesnt
