I am not too sure how to attach my cent clutch to my engine. I have taken some pics of it so that you can see what it looks like.
It does have set screws, so the inner portion of the clutch can be secured to the shaft. It is the outer drum that I am not too sure about. My shaft does have a hole in the end of it, but it is not threaded and only about 8mm deep. The drum has a bearing(?) that comes out (as you can see in the pics).
So....my question is how would you, in my case, secure the outer drum to the shaft and the inner portion of the clutch
