How to secure and install clutch
I am not too sure how to attach my cent clutch to my engine. I have taken some pics of it so that you can see what it looks like.
It does have set screws, so the inner portion of the clutch can be secured to the shaft. It is the outer drum that I am not too sure about. My shaft does have a hole in the end of it, but it is not threaded and only about 8mm deep. The drum has a bearing(?) that comes out (as you can see in the pics).
So....my question is how would you, in my case, secure the outer drum to the shaft and the inner portion of the clutch
JHen
You will need a key, 3/16" if your shaft is 3/4" and 1/4" if you shaft is 1". Put the key into the key way on the crank and the slide the clutch on so the key way on the clutch is lined up with the key way on the crank. Put the two grub screws into the holes on the clutch. There should be one over the key way on the clutch and one 90 degrees to that. The first holds the key in place and the other holds the clutch in place. Slide the clutch all they back until the clutch is flush with the end of the crankshaft. Now, get a bolt, if your shaft is 3/4" it is probably going to need a 5/16" fine thread bolt, and a washer big enough to cover the front of the clutch where it meets the end of the crank. Put the washer on the bolt and thread it into the threaded hole on the end of the crank. You've just installed your clutch.
Thanks Jhen. The only problem is that I don't have a threaded hole in my crank. The hole is also only about 8mm deep, so that doesn't help me. Will I have to get a threaded hole machined in my crank, or can the clutch drum just 'float' on the crank with the chain holding it in place?
JHen
No no, the chain won't hold the clutch in place. There should be two set screws on the clutch. One to hold the key in place and another to hold the clutch in place. Just make sure you use some loctite on the threads of the grub screws and wrench it down. Make it tight, but don't over do it or you will cause a little divit in the shaft and it could catch on the clutch when you take it off. This will be enough to hold the clutch in place. The bolt is really just for extra security.
And as far as getting one machined, not necessary IMO. You can do that yourself if you have a drill and a tap. You will need an I size drill bit. Just put it in a drill, a hand drill with a level will suffice. Make sure the crank is level with a torpedo level, then make sure the drill is level with the level on the drill. Drill in about 3 inches, backing out a lot to clear the chips. Lubricate if you feel it is necessary. Once you've drilled your hole, tap it. Just be super duper careful not to break the tap. Use some tapping fluid and back it out frequently to clear chips. If you feel heavy resistance, back it out a bit to break chips then start back in. If you keep getting resistance, back it all the way out and clears the chips out of the hole with a compressed air blast with it leaning over. Also, make sure you get the bolt for the tap you used. Don't try to use course threads if you tapped for fine threads, and vice versa.
JHen
Thanks again for your help. I just need to know how the drum would be secured with that bolt in the PTO. As you can see from my paint sketch, there is about 3 inches of crank before you get the inner section of the clutch wich have the setscrews.
If I slip the clutch housing on, there will be about 3 inches of crank left. How would a bolt in the end of the crank hold the housing which is 3 inches away. I would like the clutch as close to the engine as I can for the project I am working on
JHen
Well, you could do one of two things. Cut the crank so it is shorter, or have a spacer that is like 1" OD with 3/4" ID and cut it to length. Put this on between the clutch and the end of the crank. Have it be a smidge longer than the space between the clutch and the end of the crank.
My 10hp Honda has an extra long pto like that, I just used a 1" ID. Steel sleeve as a spacer between the clutch and end of the shaft. I cut the sleeve to lenth so the drum could float about a 1/16".
But, it looks like you could just simply Instal your clutch inboard and skip having to drill/tap the end of your crank... If your clutch will slide on with the drive gear inboard, it'll work just fine and your grub screws would be all you'd need to hold it all in place. It's actually much better to mount clutches Inboard anyway, I always do it as long as I can get the axle sprocket to line up.
Yep that's what I mean, most all clutches with a center hole large enough to slide on either way are Bi-directional, and will work just fine Inboard or outboard. That's the way most all minibikes have to have their clutches installed to line up with the wheel sprocket.
You'll find most all race kart guys mount their clutches Inbord whenever possible too, its better because it puts less strain/leverage on the pto.
Thanks Anderkart. I just gave the manufacturer that makes the clutch a call, and the tech guy says that I can use it both ways. He says that all I have to do is drill a hole in the clutch housing in line with the set/grub screws so that I can tighten and loosen them when I need to. I didn't even think that installing it towards the engine would mean not being able to reach the set/grub screw. :idea2:
So I will be doing what you say.
(edit)
Sorry I've been out of town posting from my crappy phone for the last week, but I'm back home on my computer where I can see your pics better now.
What brand/model clutch do you have there?
Maybe that tech-guy was wrong, you should be able to install your clutch just like this minibike, with the grub screw side facing out so you can easily tighten it without drilling anything.
From your pics it looks like you'd just need to:
Slide your drum on first,
then slide that spacer on,
then install a key,
then install the hub assembly with the grub screw facing outward and tighten it up.
______
Thanks Anderkart. I am going to have a look at it this weekend. I actually don't know what the make of the clutch is. I got it from a place that makes go-karts, amongst other things, and it doesn't have any markings on it. These clutches apparently get used in most of the funkarts around here, so I think it is quite rugged.
Clutches are so expensive here ($150) that I hope it works out for me.
Thanks Novaracer, but I am trying to avoid doing that. I might have to if I don't come right though, but I think I will. I will be able to give you the verdict after the weekend
To close off this thread, I took Anderkarts advice and turned the inside section out as well, so that the grubscrews also face out. It works perfectly. Just shows that not all tech guys are the smartest.
Thanks to everyone who replied
