How to remove sprocket
ashtrae311
Tennessee
Or would the 8t be too small to hold chain on with it having a 72t sprocket? Also could someone give me info on how to do jack shaft or point me in the right direction I'd appreciate it
All I can say is good luck finding an 8t clutch...
Everything points to this kart having a torque converter as standard; the 54t axle sprocket & the fact that it needs to be moved to line up with the clutch; the best solution is to put it back to stock then all the problems are solved...
ashtrae311
Tennessee
It doesnt have a converter. I have found a 8t clutch and was wanting to know if it would work. No one knows what stock was you can tell frame is made for big tires.
I realise it doesn't have a TC, I'm saying it should...
8t cent clutch to 54t axle sprocket will give you a 6:1 drive ratio; with 22" wheels, the clutch will last about 30 seconds...
ashtrae311
Tennessee
The guy doesn't even want to get a sprocket even though I explained the ratios to him. I figure I'll get smallest clutch I can find which is 8t so when he sees it doesn't work he'll already have the right clutch as long as he doesn't fry it trying it out. All I can do is what he's willing to pay for and he wants to go cheap even though it'll probably cost more in the long run with not doing it the right way the first time
firemanjim
Just kartin' around....
Houston Texas
You need to tell him a 6:1 WILL NOT WORK with 22" tires. If he doesn't want to buy a sprocket, time get a better drive ratio, well he is just not the smartest dude. It WILL fry the clutch. No questions about it......
ashtrae311
Tennessee
Trust me I tried. I sent him a text explaining it in detail and he responded with, let's just get a clutch and chain to keep it cheap. I told him ok it's your money. Some people have to see it for themselves I guess
Ok so, do just that; put the new clutch on &, when he comes back in two weeks complaining the clutch is fried, then you can say "I told you so..." ;)
Some people simply can't be told, you have to prove it by showing them...
ashtrae311
Tennessee
Yep that's the plan But I'd much rather do it the right way so the customer doesn't have to bring it back but like you said some people just have to see to believe. Thank you all for your help I truly appreciate it.
