j.concepcion54321
Rebuilding KTM, Need Kart
Hey,
I have an old kohler k91 engine with a vintage style clutch on it i removed the set screw and then i tok of the clutch bell (outside cover with the sprocket) I still couldnt get it off. i then found a snap ring in there so i thought that was holding it back. So i took it off and i removed the clutch components the spring the weights, etc. and then the back plate. Im now left with what is "hugging" the crank shaft and i dont know what to do to remove it. any help? This is the engine and the clutch.
Thanks,
Josh
Thanks,
Josh
