How to remove a sled motor and transplant it?
qtband
St. Louis, MO
However MysteryBoy, USE THE FRAME! I had all kinds of trouble lining things up on that build.
exenos
Project Nut
The only problem with that is a phazers bulkhead is aluminum and you cant weld aluminum and steel so it would have to be bolted to the buggy
mysteryboy28
Lansing, MI
pics...
i hope i didn't hack off too much of the frame. i will weld as much of it as i can to the buggy, and bolt down surfaces that are aluminum.
gave it a good washing, will spray it with some black paint tomorrow.
mysteryboy28
Lansing, MI
this concludes the adventure of removing the motor and frame... now back to my project log: "project: PGO bug racer, simplified". :)
exenos
Project Nut
Aw, I just hate to see a good sled butchered like that. Should have drilled out the rivets holding the tunnel to the bulk head, you might have been able to sell the tunnel.
mysteryboy28
Lansing, MI
i had to hack that bi-otch up good... otherwise i would have gotten frustrated at how long it was taking. 4 hacksaw sawzall blades and 3 metal cutting discs later - that's what ended up with.
now i hope i can put it all back together again on the buggy...
