how to paint
tenlizard
i have an old vintage briggs and stratton 3hp and i was wondering how you paint them it has a little surface rust. i'm restoring it. i want to sand it and paint it but i don't know how to paint it and what kind of paint to use. any suggestions?
gocartkid
Bad Attitude
CT
High-temp engine paint at your local auto parts will work. I know Duplicolor makes some, I can't remember who else does right now. Make sure the parts are 100% clean (no dirt, oil residue, etc) or the paint WILL start to flake off after a while. Using the primer that is recomended on the back of the can will make sure that the paint will last a while.
I was thinking of just stripping one of my engine blocks/head and just leaving it like that because I like the bare metal look. What do you guys think?
tenlizard
yea it'll look good so wait is the paint in a spray can?
and do you put on the primer first-or-mix it with the other paint if it's not a spray can?
gocartkid
Bad Attitude
CT
It's all in spray cans. You clean and prep the area first, then apply the primer, and finish off with your top coat following the directions on the cans.
gocartkid
Bad Attitude
CT
And a few tips: Use a fine grit sandpaper so you don't put a bunch of deep scratches on the block. There are paint strippers out there that you could use, but sanding will work. If you take the engine appart and do the covers, block, tank, etc seperatly the job will come out better. While it's apart you could put new gaskets in and (if you want it to look really good) use new bolts. I prefer to take it apart because then you can get more detailed with it.
tenlizard
yea i'm going to have to clean the carburator so that would be a good time to do it would you paint the carburator or not?
gocartkid
Bad Attitude
CT
I usually don't paint the carb. And no you don't paint the flywheel either. I paint the block, head, pull start cover, all sheilds, and the gas tank. Some paints are gas resistant and some are not, but I use a funnel when filling the tank on these things anyway (with gas so expensive every drop is $$$, lol).
I like karts
Rotary Power!
Alabama
If it's got a little rus on it, sand it down, and then spray it with some primer stuff that converts rust into grey primer. then paint the color of your choice with hi-temp paint
