How to make single wheel drive?
You wouldn't typically mount that sprocket to that wheel, but to a hub on the axle, in which it was mounted..
Equally speaking, what's the kart ect?
npragin
What type of sprocket could I use? I want to keep it 60T but the chain number can change, could you suggest a sprocket?
npragin
man, if only someone made a video about that?
https://youtu.be/0rO9H0KggsY?t=1m33s
Thank you very much for the video link, I hadn't seen that one, but the main problem is that I can't find a sprocket that would fit.
---------- Post added at 02:37 PM ---------- Previous post was at 02:36 PM ----------
Whats the OD of the tire?.... Thats a kart rim, so the tires are going to be smallish.. meaning there wont be much if any ground clearance...
The OD of the tire is 12 inches.
You need a hub for the sprocket... That also attaches to the wheel...
But more importantly... Is this for a live or dead axles kart?...
Cause these wheels aren't really for dead axle types... There isn't much room for a hub, bearings, bolts and then a register for a sprocket...
npragin
It is a dead axle, could you reccomend a wheel with the same specs?
