I have a kart and I want to convert to shifter kart. I took the old Ital Sistems MV31 off and loaded the YZ 125 on it and it does not fit properly. I can tell that the seat brackets will need to be altered. I am not sure if it will fit even then but I want to keep the seat in perfect line with the steering wheel. I don't like when the seat is offset from the steering wheel. Question here is what would you do? If I move those seat brackets the engine will be really close to the seat, Maybe get a smaller seat? Also, the engine is kickstart. You can tell from the pics that the kick start is very close to the wheel. I have seen other builds and there kick start clears. What do you recommend on this?
Thanks
Thanks
