How to fit a motor
Fhsrt
I have this Stinger frame. No motor. I can't seem to fill in the space from the wheel to sprocket to motor. With the tire and sprocket on I still have about a 2 inch gap
We're going to need much mor info on this machine of yours... And your profile..
What motor do you have?
What was on it?
It's kinda sounding you bought a preditor, and it had a tec or Briggs originally. They have a slightly shorter shaft and they don't line up right...
Might have to redrill new mounting holes...
Fhsrt
I have a Briggs and Stratton motor on another kart. I was going to put it on the two seater for me and you kids but after the clutch was put on and motor mounted there was a huge gap between the sprocket and clutch alinement. It's not a live axel so no Jack drive would not work. Also there is no back break yet but looking at sprocket/break on the back wheel it looks like it might work.
Cut off and reposition the motor plate closer where needed. Reweld and support accordingly if needed.....
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Could he use spacers? I know the factory Manco's had Like 3/4" to 1" of space and from the factory they used nuts for spacers.
Brake. :)
ML-TOYS
long island, new york
How about posting a pic with the wheel on it and the motor sitting in place with clutch on it.
Side shot, from top and from rear. As straight as possible.
I think it would be easier to see than having everyone guess what is wrong.
