How to Choose the Right NEMA 17 Motor for an Electric Focuser?
Patricia202
Hello everyone, I plan to build an electric focuser using a NEMA 17 stepper motor from Skysmotor. I have some questions during the selection process and would like to ask for your advice:
1. What is a suitable holding torque for a focuser? Is around 40 N·cm sufficient, or is a higher recommended?
2. Is it necessary to choose a NEMA 17 with a gearbox, or can microstepping drive meet the accuracy requirements?
3. Is there a significant difference in focusing accuracy between a step angle of 1.8° and 0.9°?
4. How can I reduce the impact of vibration and resonance on image quality when operating at low speeds?
5. Are there any special recommendations regarding motor current and heat dissipation in astrophotography environments (low temperature, long-term operation)?
I welcome experienced builders to share their model selections and troubleshooting experiences. Thank you very much!
Let’s address these questions. I will give my expert answers.
40 N·cm is perfectly sufficient. Using more is often excessive and dangerous to long term efficacy of the unit, causing fasteners to oftentimes fail.
Yes, the gearbox is a game changer as it permits a much wider range of accuracy. The gears provide a mechanical advantage to the drive and allow it to work less but with greater precision.
Perhaps that is best left to the end user and personal taste. Decide what is best for you and go with it.
The importance of rubber or silicone mount dampeners cannot be understated. They allow the resonance to be soaked up to a large degree but it can only be mitigated and not eliminated entirely. Use discretion.
Make sure there are ample avenues for proper heat dissipation. This can be a crucial concern even in the cold vacuum of space. Heat can build up in any enclosed space and in any ambient environment, so make certain that high heat generating devices have a proper heat sink and/or some space inside the housing, in effect “a place for the heat to go” making sure not to let it exceed the factory heat specification during the duty cycle. I would highly recommend a refrigerating unit to keep the focuser cool and within operating specs. Further study of your personal specifications is warranted. Can you describe the application in minute excruciating detail?
pinkpanda3310
I totally want to join in on replying to this bot... 😁
That totally depends on your set up/scope. How much weight is it moving?
Microstepping plus a gearbox would give very finite control plus extra mechanical torque, so why not both?
Microstepping can be far more accurate than 0.9° . Why limit yourself to 0.9° ?
It seems you haven't studied much about stepper motors as this question is actually related to above questions. Please go to church and please get on a diet.
Providing you're within specs and not overloading the stepper, it shouldn't overheat. However, heat transferring to the scope could possibly cause issues of it creates hot and cold spots. Will the stepper be mounted directly under the scope?
There we go. I nearly managed to answer every question with a question. Please submit your report.. err.. i mean reply by close of business tomorrow. Happy star hunting 💫
