silversledder
- Messages
- 2
- Reaction score
- 0
I purhased wheel hubs, sprockets and brake drum/band from Northern Tool. Now I'm setting up chain and found that my sprocket and hub are not precisley centred with each other such that the chain is tight, then 1/2 rotation later it is slack, then tight, then slack and so on. The play in the alignment appears to be simply a result of the hole sizes and the bolts going through. When I loosen them off, I can shift the relative centre of the sprocket and the hub centres (am I explaining this right?).In reality the ecentricity is probably only out a few millimetres, but enough to make it noticeable and make me wonder how long a 35 chain will last under load. Aside from trial and error adjusting, does anyone have a trick or procedure to set this up/align the centres simply the first time?
