how to buy go kart tires and wheels (rims)
PatiencePaysOff
I would like to know how to read the notations (the numbers) engraved on a go kart tire. Therefore, how do we relate these numbers to the right wheels we want to buy afterwards. Do they have to exactly match? This is for a slick tire I want to purchase on Kijiji :http://www.kijiji.ca/v-pneus-jantes/longueuil-rive-sud/4-pneu-pour-go-kart/1075299006?enableSearchNavigationFlag=true and the wheel which I want to purchase from cometkart https://cometkartsales.com/Williams-1-Piece-Wheel-5-X6-Thru-7-X6.html
I know there are probably not matching, but this is where I need help to make the right pick next time.
Thanks everyone!
crazykart
Crazy member
Swartz Creek, Michigan
Those rims will fit a tire thats 6" to 7 3/4" wide, 6" around. When looking at tires the first number is the height, second is the width, and third is rim size.
Those tires are for a 5"rim so they will not fit, besides that they are 11" wide at the bead (surface that seals against the rim) so again, will not fit. The height of the tire doesnt matter when comparing them to rims.
anderkart
Surprise Arizona USA
These rims would fit those Mojo tires fine:
Front: https://cometkartsales.com/Douglas-Polished-1-Piece-Wheel-4-X5-SKU12979.html
Or Spindle mount front: https://cometkartsales.com/Douglas-DSM-Front-Wheel-Polished-5-x5.html
Rear's : https://cometkartsales.com/Douglas-Polished-1-Piece-Wheel-8-X5-SKU12992.html
Here's a link to a good racekart tire/rim fitment chart:
http://www.russellkarting.com/range.htm
_____________________________________
Have you already confirmed if your kart needs rims with the metric or american 3-bolt pattern?
