I am building a YZ 125 shifter kart. I have two frames. A intrepid frame with matching axle bearing carriers and a wildkart frame without matching axle bearing carriers. I want to use the wildkart frame because it is a shifter kart frame where as the intrepid is more for a rotax.
If I use the axle carriers I have now on the wild kart frame I can get 3 bolts per carrier, and that is if a make small adjustments to the holes on the frame. The bolts would be, two on the bottom both side, then one on top.
Is 3 per axle bearing carrier enough? Or should I look into new carriers?
