How Important is Eliminating Steering Slop?
wesleyb82
Long Island, NY
Private Stewped Kwestian reporting for duty
We have some slop in one of our karts. It's my sons and I'm too big to get into it to test it. I ask him if it's a problem and he just shrugs at me.
The wheel when the kart is not moving moves a few degrees left and right.
When I drive my car and there is slop I tend to ignore it and everything just seems to work unless it gets very sloppy but this might be because my car has a tendency to drive straight and idk if his kart does this.
Is a small amount of slop acceptable? This seems like a stupid question even to me but sometimes people come up with things I never even consider so I'm throwing it out there.
:flamesuit:
Scout
Nutjob
Indiana
I would think that a couple degrees is ok. Something like a quarter inch or more I'd bee looking for the slop.
Poboy kartman
Senior Moments Member
White Settlement Texas
I would definitely try and track down why there is play there.....
A bit of slop on it's own is not a problem. .....but if something is about to break......
Half-breeder
"Edit" button removed
I 'believe' I know of the 'slop' you are speaking of... steering wheel moves left n right an inch or so w/out the tires turning... IMO, if the kart is slow enough(<20mph), it wont make any difference/issues.
However, the stiffer the steering, the 'better' and afew degrees of looseness + a bump = a turn/sway. So, knowing that;
If the steering wheel is what is causing the play(or partial play), acouple locking screws can be drill/tapped to secure the wheel/hub, to the steering shaft.
If the steering shaft/tierods/spindle connections are loose, try a larger/more snug fitting, bolt(if applicable).
If the tierod ends/bearing are loose, then I recommend replacement.
If the whole spindle 'wiggles', check spindle pivot bolt(kingpin) both, top n bottom, ensure no groove worn in the bolt.
If the wheels/hub wiggles on the steering axle, ensure end bolt is 'snug'/locked into place, and check bearings(may need to replace bearings).
...remember a fraction of a degree/looseness here + there add up.
wesleyb82
Long Island, NY
This is a 15mph kart with no suspension, so tight steering could make it too responsive/darty over bumps? Am I understanding that correctly?
The slop is between the steering shaft and pitman arm. I was going to cut a sliver of metal and stuff it in there but figured I'd ask here first.
firemanjim
Just kartin' around....
Houston Texas
Nah, just let it be..... If its not messing up the steering or handling, it ain't broke, so no need to tinker...... :lolgoku:
