many people simply have no idea about physics....
There is absolutely no point in gearing a single speed vehicle to go 60mph;
not with a cent clutch;
and the reason is as simple as it is obvious.
at one point in time the clutch wants to engage, when just a moment earlier it was NOT engaged at all.
And that's where physics will kick your 455!
gearing for 60mph @ 5500 rpm means
at the very same time gearing for 20mph @ 2000rpm
and that can be read as the most stupid idea on a conventional cent dry clutch you could have!
Still don't get it?
ALERT
People with common sense do not need to read the following novel of heat and demise
Well then, allow me to explain:
Your kart doesn't move at all, the engine is idling happily at ~1200rpm and you're anxious to see what would happen if you kartapult your behind to 60mph in a kart that's made for a 10yo and far from being made for speeds even close to that number.
Anywhoo, you hit the throttle and the engine revs up to 1800rpm, the clutch shoes now move at roughly 9.5 m/s (21.25 mph) and are trying to get hold of the still stationary clutch bell.
Since the clutch bell is held stationary by the chain and the yet unmoving axle/tyre
all it can do is rub slightly but with a high rate, which isn't actually transferring power, it only produces heat.
you accelerate further, and all that does is applying more pressure on the clutch shoes (centrifugal force)
say 1900 rpm the shoes will ow move at 10m/s (22.36 mph) and still can't get hold of the bell very well, since it's still not moving, at least not very fast.
So you produce more heat, and the hotter the clutch will get, the less power will be transfered and the more power will be converted to heat.
and that's where the dog bites it's tail
eventually the clutch will be at it's "fully locked" position, or what's meant as such
at around 2000rpm (10.5 m/s or 23.5mph)
and that's the point where your kart finally begins to move.
the clutch is already smoking hot, likely discoloured by now and thus all warranty is voided;
but the kart starts to crawl very very slowly, and you feel like you showed us all;
But you forgot... the kart
MUST GO 20mph for the clutch to fully engage.
So it's still slipping and likely you still step on your throttle since your mind tells you "more is more"... and it is.. the more you try to accelerate, the more heat you apply.
Unfortunately, it's not more power, since that ratio is off, it's less power, and since the clutch is slipping it's even less than you'd expect (or even calculated) at all.
Who cares, the kart is moving finally... and you do get faster (since you started downhill or something) and eventually even hit the 20mph needed to fully engage the clutch;
and it only took about 30 seconds...
all good right?
WRONG!!!
Your clutch is now annealing likely even deforming
or to use a term you might have heard... it's TOAST!
you've driven your kart, that much is true...
but the next time you start from a dead stop it'll slip some more.
I doubt you can use that clutch a second time to be honest, but in case I'm wrong;
a third time is out of the question for sure.
So a new clutch has to be bought.. a racing clutch this time... those can withstand lots of abuse right?
right... it'll hold twice as long and costs four times as much!
Do the math !!
Now, for the price of a racing clutch you can go and buy a torque converter;
much better idea, it'll reduce the stress a good amount with it's internal gear ratio.
(even enough to maybe get away with that ratio of yours)
So, after burning a cheap standard maxtorque SS and maybe a Noram racing clutch you end up buying a TC
and finally try to hit 60mph..
just to find out that at 45mph the kart starts to act strange,
but you're the toughest manliest man alive, right?,
So who gives a flying shirt.. you still have 1500 rpms to go...
that's where the cheaply made kart will do the rest.
the improper steering geometry will wobble a crack or loosen a crucial bolt;
that flimsy plastic steering wheel brakes since you clench a little too hard
(no matter how tough you think you are, this will scare the brown out of your backend)
and the rest is all but violets in bloom and bird songs.
It's simply not made for speed, not meant for speed...
But go ahead, get your Darwin Award as long as it's still hot.
