another double post
does anybody know if this driver (
http://www.bmikarts.com/item/40-Series-Torque-Converter-Driver-1-Bore-454010-7852 ) is compatible with this driven(
http://www.bmikarts.com/item/Comet-40-Series-Driven-Unit-34-Bore-209133-6937 )? the only reason I ask is this driven(
http://www.bmikarts.com/item/40-Series-Torque-Converter-Driven-78-Bore-464778-7853 ) has a 7/8 bore and I can not find a jackshaft to fit it
and the first driven is cheaper so if there is a way to find the right jackshaft I would love to take that rout as long as there is a 9 tooth #40 sprocket to go with it
EDIT: can all #41 sprockets fit #40 chain?
Ok, here are a few things we learned about torque converters (unfortunately AFTER we bought everything)
There are true "Comet Torque Converters" and there are "Off-Brand (probably Chinese) Torque Converters" The website we used to buy our two sets of TCs is right here:
http://www.gokartsupply.com/4044seri.htm
NOW... as you can see... it LOOKS like they are Comet Drivers and Drivens... but the ones on that page are NOT. They came in a box called "Thrustkit". Later, after looking, we noticed that GoKartSupply DOES sell some actual Comet products, and they are "mixed in" with their other products... somewhat deceiving. You COULD hypothetically buy an off-brand driver (like the ones we have... which seem just fine) and an actual Comet Driven... but I don't think I would be very confident in mingling two different companies products.
In other words: The actual Comet Brand items cost more. So, if you go with a Comet driver, and a less expensive off-brand Driven to save money...it COULD work... but I would go with all-one-brand myself.
If I could "do it all over again"... I would buy a BMI 40 Series Comet Brand Driver for 149.95$ (the same price as the off-brand ones on the other website... ahhhh... got ripped off) AND for the Driven, I would buy this for 139.95 at BMI ( 50 dollars cheaper than the other website!)
http://www.bmikarts.com/item/Comet-44D-Series-Driven-Unit-34-Bore-209621-7530
It is a driver that is 1 inch BIGGER O.D. than the ones we bought. It would offer more lower end torque, and still give you the 1:1 ratio on the top end.
Your jack-shaft would have to be 3/4" with that driven, but that's ok... you know you would never snap it!!
NOTE: on the 9-tooth sprocket you want to use... I could NOT find a 9-tooth that would fit on a 3/4" shaft. I had to go with 10 tooth. If you go with a 7/8" driven... that's an EVEN BIGGER jack-shaft, and you might only be able to fit a 12 tooth on that size shaft.
Good luck!!!
Edit: I am not sure about the #41 Chain on the #40 Sprocket. If you can, I would just stick with #40 chain all around, and #40 Sprockets. After looking at our chain... I think anything smaller would probably break!
