I've tried turning it on already and its not cranking, I just got it checked out too. should the green wire in the picture be connected somewhere? Where is the killswitch?
Pull the plug and attach it to the plug wire. Ground it on the block to see if you even have spark. If not then just disconnect the kill switch completely and see if it has spark then.
He means to take out the spark plug. After you do that leave it connected to the wire that goes to It (sparkplug). Then hold the spark plug in your hand and have someone else pull the cord to start the engine. If it has spark it will give you a jolt of electricity, nothing major. If it doesn't then something is being grounded somewhere. Post up a walkaround vid of the engine and all the wires. Also post your throttle, I've seen some engines that cut off the spark and turn it off when you let go of the throttle so you have to have the throttle pressed so that it runs. Take that vid and do the spark test so that we can determine your problem.
I think that wire is what your kill switch should be hooked to. So you may not have a kill swith wire in. What I was saying is, the spark plug wire. Take the spark plug out. Attach the spark plug to the spark plug wire. Set the spark plug on the block. Pull your starter cord. You should see a spark in the plug gap. No spark other issues. Spark, fuel issue. Make sense?
