How do you remove that.. blade holder?
ok so i yanked it off with a puller, fixed the valve and now the engine is out of timing because i forgot about how in an OHV, the cam gears have a dot. however for those that misunderstood.. this is an OHC engine with a timing belt. now, the valves dont open/close at the right time, so i dont know.. is there a mark? will i have to open/reseal the crankcase?
This will set you straight
http://www.hobbytalk.com/bbs1/showthread.php?t=147397
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Read it and attempted it with no success. Very irritating.
I lined up the arrow on the crankshaft with the mark on the cylinder sleeve perfectly (or at least I thought so). For the camshaft, I was as precise as possible at lining up those stupid lines with the cylinder head. I then, carefully slipped the belt on both gears and went through the whole process of scraping the old silicone away, sealing it up, putting a million screws back in, and the entire intake assembly only to have the recoil jerk back in to the engine as if there's no compression release mechanism (there is a release because 1. It's a residential mower 2. I saw it.) I am considering to pull the piece of crap apart again and try to find where I went wrong. With the exception of a few pictures on some replies to threads found on Google, there's no specific instructions or pictures on how to do this. In my opinion, it's a pretty stupid way of making timing marks when you contrast it with an OHV engine that uses a simple bevel in the gear teeth. Someone help?
Russ2251
AZUSA:Powered by LAWN-BOY
They could've designed it much better.
They (Honda) could have designed this engine much better but chose not to. The point of this design was to keep costs down.
This engine will outlast any equivalently sized Kool Bore B&S.
These are not the pics I wanted to post, but is best I could come up with.
For ease of assembly, remove camshaft axle.
