how do you get old driven part of torque converter off of jackshaft?
kfiralfia
So I'm rebuilding an old Carter go-kart, and I'm replacing the torque converter. The problem is that I can't get the driven part of the converter off of the jackshaft. These are old parts, so they are not exactly loose. I drenched it in WD-40, and tried hammering it out, but no luck. I don't care about the driven torque converter I just care about saving the jackshaft.
Is there a tool or a technique that removes a stuck disc off of a shaft?
Please see the attached pictures of the driven unit on the jackshaft. Thanks for your help!
Millwright
A good penetrating oil, like liquid wrench.
Not WD-40.
Set it on end so that the oil can seep down in.
Let it sit for as long as possible, like days!
Re apply the oil every few hours.
Time is your friend with this method.
Millwright
Just another thought,
You never know... red lock-tite?
You may need a bit of heat on it.
Lock-tite or not, a bit of heat doesn't hurt.
Keep the heat on the hub, not the shaft.
