KartFab
8 hp briggs and stratton. I know about karts but not much about engines, I finally got this baby to run I had to:
install new seals for the carb to intake,
install new gaskets for the carb
install new needle? as someone had wrenched it down
bend/sand down where the carb mated together as someone had wrenched the three bolts that hold the carb together so hard over a too thick home made gasket that you could see daylight through the carb with the right gasket on it...
someone had stripped the bolt out where you screw the governor/throttle assembly to the carb as well as the air filter to the carb..... i bought an el cheap o 10$ tap and die set at harbor freight and tapped it out to the next biggest size with my drill and it worked!
Anyway I am kind of excited because now All i have to do is hook the gas tank back on it and install a kill switch and it will be ready to put on the kart.... only problem (besides a crack in the gas tank that i will epoxy shut)is this...
It looks like the wiring (or lack thereof) for a kill switch is absent from the engine itself. I am thinking I will have to pull off the side cover and hook something up to the wires coming out of the magneto? NO CLUE WHAT TO DO HELP!!! I'm such a newbie when it comes to engines. Trial and error, I think i have a general idea but want to know what you all think...
just as effective as a factory... and ALOT more reliable than my initial idea of tieing a sting to it n pulling it when you wanna kill the motor...
