How do I get my lights to work??
kendelrk
redneck engineer
westland michigan
have you tried touching it to the other terminal? if so i would get some bateery ends for cars attach it, strip the wire push it in and tighten it down
95badbird
Srping TX
as soon as I saw your ground, i stopped the video.
you need a better ground.
scrape paint away to get in contact with bear metal.
or get a screw into the frame for that connector.
95badbird
Srping TX
also, you need to run a ground from your negative terminal to the chassis itself.
did you follow the wiring diagram that came with the lights?
it would be best to wire a relay, as that switch could potentially get hot and melt, trying to carry all the load.
I am an enginner by trade, and as you can see in the pic, this is a relay board I made for my race car.....
relay rack..
switch panel i made....
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Your name must be jerry because you sure have rigged that stuff.
x2, paint isnt a conductor. Drill a small hole, sand the paint off around the hole, and screw that connector to the frame.
Is didnt look like you have a wire running from the negative battery terminal to the frame, do you?
