How do I fix this?
SlowNstonie
The back axel maybe? Moves side to side causing the chain to pop loose. How can I fix this?
Budget GoKart
Aka a kenbar
roachdale, indiana
in that case if you want to save it it will require cutting and or welding i suggest you replace the rear end a dead axle is two 5/8s bolts and a long peice of square stock
