How common is a reverse rotation engine?
afremont
houston
So, I got this walk behind edger (actually I have 3) that I picked up with a bunch of other junk lawn equipment. It's a horizontal shaft 3.5HP B&S. Unlike my other two edgers, this engine has the carb up front, the pull on the left side and the PTO (shaft) spins clock-wise when viewing it from that side. That puts the cutting bade on the right of the machine. It was sold my murray. The edger is inconvenient for a right handed person to start because you have to pull it with your left hand.
It seems that most horizontal motors that I see online spin counter-clockwise when viewing the PTO shaft.
How common are reverse rotation engines?
I don't know how old it is, but I'd say it was made in the 80's. It has a choke and a manual throttle that really only runs at two speeds idle and fast (limited by the governor). It turns off by grounding the coil out when you slide the throttle all the way to the left. If it were mounted vertically (lawn mower style) it would be spinning CCW when viewed from the top. Is that weird or what?
afremont
houston
:oops: Yep, I must have had a senior moment there. I'm eating right now, but I will post the pics in a few. The edger is made in reverse, but the motor is like any other. I made the dumb assumption that the blade spun in the direction a wheel would turn pulling the edger, this one goes the other way. It kicks debris to the front unlike the "normal" models. Man, I really thought I had something unique there.
afremont
houston
Here's the pics. I apologize for making a fool of myself here. It is a pretty good little motor anyway. The flywheel was so rusty it would hardly turn because the rust was scraping on the coil. The fuel tank had something yellow in it that smelled like lamp oil. I pulled the tank, sprayed it out with carb cleaner and sprayed through the carb parts I could get to without really disassembling it. Change the oil, poured in some gas and it started on the third pull. It runs pretty good after adjusting the jet screw until it stopped popping every 10 seconds or so. It idles so nice that I turned the idle screw till it putted. This thing was covered with surface rust until today. Well every where that someone hadn't done a spray can rebuild with black paint. The guy I got this stuff from seemed to like doing that. :/
Anyway, here you go. The green framed one is the oddball lefty model and the Tecumseh (missing tank and carb stuff) is the "normal" style. Sorry for being stupid. :(
afremont
houston
I never owned any horizontal shaft lawn stuff before. I think you all can see how the gokart bug got into me after picking this stuff up for a song. I'm trying to set up a deal with a kid that has a nice looking yerf dog 3203 (that's what it looks like anyway). He doesn't want money, he wants to trade for a pocket bike so I found one for him. ;)
He says the kart only needs a belt (torque converter), but I'm sure it probably needs a little more than that, still it looks pretty decent though. It looks like I might end up with it for $300 which is at the edge of what I wanted to spend. But since it's got real suspension, I'm on board with it. Most people around here want at least $800 for something equivalent.
Poboy kartman
Senior Moments Member
White Settlement Texas
Not stupid....just ignorant....and now you aren't! !!
Like I said..."Been there...done that!" That's how I knew right away what you were talking about....I thought the same thing with that exact same model green edger....I must confess....I don't know why they did that....because the 2hp's are set up the other way....
It's a gravitational thing; think about magnets, they have a north & a south pole, just like the earth; you're closer to the north pole so the gravitational pull goes one way, being closer to the south pole means the gravitational pull is opposite...
Or, something like that...
Maybe this will answer your question...
FYI: I have personally observed this phenomenon, having traveled to the US...
