Okie dokie... I am swapping the Fun Power 5 for a Predator 212. I bought some parts online and one of them was a top plate, therefore I had to remove my fuel tank. Now I have my fuel pump mounted, but I need a pulse to run it. There is a port cast into the valve cover. It used to dump into the airbox. I would use it but I am concerned that blowing will build and it wont work correctly. My other concern is that if I have a breather on that valve cover I wont have enough pulse to pump fuel. Unfortunately I havent found much tech on this, although without having internet at home its hard to search.
