OK...so I bought a Thunder Kart frame and it came with the clutch and tires. I then bought new tires and the Predator 6.5 hp from HF.
Have done alot of reading threads to make sure I got things right hopefully.
I have 13" tires on the back.
10 teeth on clutch.
54 teeth on sprocket.
Clutch has about 1/8" play on shaft.
Can't say that clutch and sprocket are exactly aligned either.
Myself weigh about 170 and my son 60, so about 230-240 lbs.
So 5.4:1 ratio...correct?
Was told not to lube clutch, but other threads make it sound as though you should....if so where?
And is it normal for clutch to be to hot to touch?..not smoking or red hot, but to hot to touch.
Also the way the gas pedal is mounted you can only get about half throttle on engine so I figure that speed is no faster then 25mph.
Any helpers or pointers would be much appreciated....Have always wanted a go kart and my kids are enjoying it alot!
10 teeth on clutch.
