Horsepower relation to CC or CI
mike75925
thinker and tinkerer
Alto, tx
stroke x bore x rpm + type of fuel + weight of rotating assemblies + compression ratio + size of carb, etc. when an engine is rated, or so i've read, it is rated with no exhaust, and no breather assembly. this might get you a ball park figure.
Russ2251
AZUSA:Powered by LAWN-BOY
A 100cc Yamaha KT100 can get you 9 to 15hp.
One of my 141cc Lawn-Boy engines will produce 6.5hp in it's stock configuration.
There is no empirical relationship between between cc's and hp. Many factors come into play.
"X" cc's does not equal "Y" hp.
freakboy
the names 'mater
hick town
also another example is tylers engine of awsomeness just cause its stock cc dont mean its stock power all the mods he did to make it bad *** and kick *** lots of things factor into power more then cc.
mike75925
Alto, tx
they try to keep a baseline on certain kinds of motors. aaxion? is a 50cc rotary that puts out 50hp. suzuki had a 500cc, that put out like 50horse, and mazda long known for using the rotary, i doubt has gotten that kind of power as of yet. r/c engines sized .21ci can put out around 3-5hp, but they are basically diesels and run on nitro-methane.
mike75925
Alto, tx
ah, but there are diesels which require glow plugs, and they do make a diesel conversion kit for most of the r/c engines. they use a glow head instead of plugs.
Russ2251
A diesel engine requires a glow plug for it's initial start-up and then turned off once the fuel can fire or "crack" of it's own accord.
A model airplane engine uses a glow plug for initial start-up and continues to glow (thermal inertia and catalytic combustion reaction) after power source is disconnected. Very similar to a Coleman lantern. Without the glow plug, the model engine will not run.
Also, none of the model diesel engines I own use a glow plug of any sort. They simply start with a mixture of kerosene, automotive oil, and ether. No ignition source.
mike75925
Alto, tx
ok, so on diesels that do use plugs, do they not do the same? thermal transfer? i've heard that diesels run comp ratios of anywhere from 20:1 up to 200:1, the later seems kinda high. anyway, if the fuel is compressed to the point of ignition, heat will be a factor in it's firing. to what extent, i am not aware. on a side note, i have ran two-stroke mix in an r/c engine, ran like crap, but did run.
mike75925
Alto, tx
would not the firing of diesel cause the filament or element to glow again? or is it that the compression is so high, that the heat is inconsequential?
Russ2251
So ur tellin me a diesels glowplugs wont glow even when the engine is running but a nitro engines glow plugs will still stay red hot
Yup.
they wont suddenly stop and get cold just cause they dont have power going to them
They don't stay hot enough to ignite anything in a diesel.
BOTH PLUGS WILL STAY GLOWING WHEN THE ENGINES RUNNING!!!!!
Prove it.
Rickracer
RM250 Race Kart Driver
Kissimmee Fl.
Freakboy, Russ is right, diesel glowplugs don't glow with no power, they are of completely different construction. RC glow plugs are just a wire filament, sorta like the ones in a light bulb, fairly fine wire that glows with fairly low voltage, diesel glow plugs are much thicker wire, and it takes a LOT of current to make them glow. Nitro motors compress fuel and air together, once the mix is compressed enough, it lights off. Diesels compress air only, the fuel is injected at exactly the right time and lights off immediately, so you can change the way they run by adding more or less fuel, and changing injector timing, all you can change on nitro motors is port timing and fuel mixture. ;) :cool:
Russ2251
Not worth arguing about.
Luckily, most of us "get it".
There's a big difference between folks who know the answers (through education) and those who "think" they know...and show their lack of education.
Rickracer
Kissimmee Fl.
Not trying to argue Russ, trying to educate, but as the old saying goes: "You can lead a horse to water.....", ;) :cool:
