Any one got any pictures on how they hooked up the throttle on their new HF clone? I know how I was going to do mine but the bolt broke so I quit for the day..... Seeing if someone had a easier solution than what came up with
yea buddy! i had a pic of one about a year ago and this is what i do now. dishwasher door spring for the return keeps it returned EVERY time very safe. the crimp bolt is just a random bolt i had laying around, and drilled a hole through it right under the head.
I tack welded a hex head bolt in from up thru the bottom and then drilled a hole through it for the cable but the bolt snapped in two when tightening it down. I am going up a size and switching to a grade 8 bolt but I need to grind the head down to fit. The throttle control arm has a pretty big stiff return spring on it so I think I will be alright there.
