karl
I bought a honda xl70 1974 off cl for $40 with a 5hp briggs, 20in by 10in tractor tires, and a max torque 3/4 35 chain clutch. I bought the motor I will use for it for $40. Powerwasher had a bad pump. 5.5hp briggs intec. Runs good. The bike was striped and dident come with a motor, but has good tires and brakes. I ordered all the parts from bmi carts. It will have a 30 series tc, with the gear ratio it will top out a 35mph. I ordered a comet steel backplate with cover, js, bearing, ect. Then a 8 tooth sprocket , and chain. Once the parts come (should be soon, BMI is in Ohio and so am I) Ill mock everything up and start welding. Many updates to come.
